3D Printed The Wounded Ghosts
3D Printed The Wounded Ghosts by 3DGeex
Spooky season is coming so I'm focusing on Halloween stuff! Knew that I wanted to do some ghosts but also knew I needed to give it a twist - This is The Wounded Ghosts! The entire set is multi-part so no AMS/Waste with this print - Just a few drops of glue ?
Printing:
  • All ghosts require supports - Use tree/organic supports.
  • Print at 100% infill so you don't have any infill patterns, don't worry the prints are very light on material.
  • Use an internal brim if you have adhesion issues.
  • Axe + Chainsaw Body require supports as well.
  • Do a filament swap mid print for the Ghost_1_Blood+Knife to have it in 2 colors.
Assembly:
Assembly is super simple and each ghost will require some glue - just look at the file names and you'll get the idea You can easily scale up, if scaling down watch out for the wall thickness and don't go too small...
Default size will fit a standard led tealight
Highlighted models from 3DGeex
