3D Printed Bad Carrot
3D Printed Bad Carrot by 3DGeex
With that being said - A new bad member is joining the family! Meet Bad Carrot! This one is a little different then Avocado & Peach as it was not really possible to hide the hands inside the carrot in the same way as previously, So I made something completely different. It's multi-part so no AMS/any other Multi-color is required.
Printing & Assembly
  • Print the carrot with Organic / Tree supports where necessary.
  • All other parts do not require supports.
  • When printing the Pot_Cover make sure you have a single layer line for the openings - take a look at the included image. This means if you are scaling it up, make sure to push the model beneath the print bed if it becomes 2 layers or more! Your first layer must be flawless.
  • Attaching all parts may require some glue.
Assembly is super easy with every part fitting it's place, you might want to use some glue to connect the parts and you probably should use some for the Pot_Cover
Highlighted models from 3DGeex
