3D Printed Toothpick Dispenser
3D Printed Toothpick Dispenser by FlorinV
The Automatic Toothpick dispenser:
  • All parts are 3d printed, all in one plate. No AMS needed.
  • Several Lids to choose from and a clean lid to customize it as you wish. “Voronoi” and “Yoda” lid are found in the model profile. Other optional lids will be added to the “Optional Lids” profile.
  • Each part easily fit together. Please check the short building video bellow. ( 1min 30sec minutes to build )
  • works with toothpicks of max 66mm and approx. 2mm diameter (normal toothpicks I've found ). Please shake the dispenser to arrange the toothpicks correctly and parallel. Throw away toothpicks that look too different than normal ones: damaged, askew.
  • The two arms that hold the big parts together have printed on them L and R, to be sure you set them correctly (left and right).
  • The 3d printed spring should be inserted like in the video, first on the back with the other end up, then the front.
