3D Printed Hinge Ball transforming Fidget by RuvenBals
this is a Fidget Ball that changes shapes and colors when you throw it in the air. It's a variation of the Uekitahedron I did with Keishiro Ueki that I invented.
You need:
  • 4 Left Pieces
  • 4 Right Pieces
  • 12 Connectors There is also an "All" Plate that you can print. It has everything you will need in one place. Multicolor files are also included, as well as a tool that can help with assembly.
Print Settings: The individual pieces are print-in-place—no supports required. A brim may be helpful depending on your printer. This model is a little filament-dependent. Use a filament with a smooth surface that slides well against itself for best results.
