3D Printed Gear Cube
3D Printed Gear Cube by RuvenBals
You need: Everything is included in the "all" file. Or print: 4 Big Gears 4 Small Gears 1 Heart 8 Connectors
Print settings: No supports needed. Just print with a standard profile.
Assembly: Push the connectors into the heart and then put the gears on top. Apply a lubricant to the connectors if you like.
