3D Printed Articulated Hand MkII
3D Printed Articulated Hand MkII by bradpaiva
Unleash your creativity with the Articulated Hand MkII — a highly poseable, biomechanically inspired articulated hand that's both stunning and functional. Whether you're into props, desk toys, anatomical studies, or just cool designs, this model blends aesthetics with motion in a unique and satisfying way.
Key Features & Improvements
  • Biomechanical Design – A bold, new, stylized look with a futuristic edge
  • Shell-Swap System – Outer pieces press-fit for easy color swapping — no glue needed
  • Redesigned Joints for Increased Friction – Stronger poses, better stability
  • Redesigned Thumb Path – Improved range of motion and realism
  • Realistic Finger Proportions – Now with more accurate human-like scaling
  • Reinforced Base – More stable than before
Print Details
  • Works with All PLA – Optimized for PLA, including PLA Silk (just go easy on the joints during assembly)
  • Color Grouping – Print profiles are organized into Core and Shell parts for effortless multicolor setups
  • Custom Colorways – Mix and match filaments to create your own stunning combinations
  • Use your fanciest filaments for best results.
  • No AMS Required
  • Designed for:
    • 0.4mm nozzle
    • 0.2mm layer height
    • Approx. 8 hours total print time
  • Minimal supports required
Assembly
  • Easy to Build – Straightforward assembly; many users can put it together intuitively
  • Assembly Guide Below – Highly recommended for best results
  • Just one drop of glue needed: thumb connection only
  • Pay Attention to the Wrist orientation, a lot of people are getting it backwards
