3D Printed Addition & Subtraction Fidget Spinners
3D Printed Addition & Subtraction Fidget Spinners by 3dogprint
Addition & Subtraction spinners
In this print profile there are separate plates for each spinner 2 through 9. One side has addition and the reverse has subtraction.
Everything is flush on the first and last layer so if there is difficulty seeing the numbers slice the model and you should see everything. I prepainted each spinner so you do not have to. Just select your colors and print. Each spinner takes about 1.5 hours to print. There is a profile for each on individually as well as a profile for all of them on separate plates. Please enjoy
Highlighted models from 3dogprint
