3D Printed Passthrough Traffic Cone by GemoGens
This design is special as it needs no AMS to print the 2 colours!!
This is achieved by adding stops after certain layers are finished and then manually switching the filament.
I added a profile for that which you can use, or you can manually input the stops at your desired heights.
AMS and single colour versions are also included!
This model is SCALABLE so make sure you take advantage of that!
You can print it in place as is or separate the parts, I tried printing as is and it turned out great! Just one small top part got stuck which i had to break off and everything worked perfectly afterwards!
