3D Printed Impossible Vortex Passthrough illusion
3D Printed Impossible Vortex Passthrough illusion by RJDesign
Building on the well received impossible passthrough illusion. This is Version 2
It fixes the problems present in the first Design.
No more messy overhang, a good slide straight after printing, and much better bed adhesion.
This is a fun piece and can be used as a fidget toy as well
Dimensions are approximately: diameter 46mm x 50mm
Let me know if you experience any issues.
If you enjoy this print consider giving it a boost (It'd really help me out!)
Printing
The Print Profile should be used if possible. The hour glass object should have auto tree supports enabled to 30 degrees, and a layer height of 0.16mm, the barrel shape should have no supports and a layer height of 0.2mm
It is set up to print by object (1 part then the next)
Highlighted models from RJDesign
